Hello/
OS linux ubuntu 24.04 live server/
Docspace from wiki package
I installed docspace community on a local server with IP address 192.168.0.100/24. The server works great, invitation letters are sent, etc. Within the local network, any device has access to the docspace server. there was a need to gain access outside the local network. Since there is a white static IP address, ports to the docspace server were forwarded on the router side. however, when trying to log into the server using a static external address, an error appears
Application error: a server-side exception has occurred (see the server logs for more information).
Digest: 3576187290
16-41c7a4cff29cb95e.js:1 Error: An error occurred in the Server Components render. The specific message is omitted in production builds to avoid leaking sensitive details. A digest property is included on this error instance which may provide additional details about the nature of the error.
i dont need ssl or https , and i dont need any domain for that server/ just only access for me outside the local network to the server via an external static IP address
