Hello everybody,
I’d like to delete a row from my spredshet-document via a macro. For this I tried the following code:
let objZeile = objTabelle.GetRange(intZeile + “:” + intZeile);
objZeile.Delete(“up”);
Where “intZeile” is the number of the row to delete and objZeile is the range-object.
All lines of code are executed but obviously not this lines(?) as nothing happens.
Can anybody help.
Thanks and regards
Hello again,
just two additional pieces od information.
I tried:
objTable.GetRows(intZeile).Delete(“up”);
as recommended in some older post - with no success.
And as mentioned in the post I tried it in both online and offline editors to the same result.
@Dimpflmoser
Hello, unfortunately, the Delete method is currently not working due to a bug. It should be fixed for the upcoming 8.2 version. Sorry for the inconvenience
Hello Dimitri,
thanks for your answer! Can you give me a time frame when 8.2 is due to be released?
Thanks again
@Dimpflmoser It should be released this month
Hello @Dimpflmoser, the delete method is working properly on new 8.2 version of Document Server, the version has been released, you can update now
