ONLYOFFICE Mobile: Documents (spreadsheet)
Do you want to: Report a bug
On the iOS app, if you use a coma “,” instead of the “.” formula do not work
example : in A2 input 2,2 in B2 input = A2+1 you should have error #VALUE
in A2 input 2.2 in B2 input = A2+1 you should have 3.2
Device: ipad
OS version: 16.4.1
App version: 7.3.3.53
Mode: On Device
Hi @iraza
It depends on the settings of the region you are using.
And specifically from the decimal separator
You can change this parameter in the browser settings
Desktop:
File > Advanced Settings > Regional Settings > Decimal Separator.
Mobile
mobileApp: > Language and Region >off Set Automatically > Select region or Set special separator > Decimal Separator.
