Debian 12 (bookworm) repo?
Document Server version: 7.5.0-125 adm64
Type of installation of the Document Server : deb
OS: Debian 12
Browser version: none (server)
Hi, would someone know if there is a Debian 12 (bookworm) repo for onlyoffice-documentserver ?
I tried:
deb [signed-by=/usr/share/keyrings/onlyoffice.gpg] https://download.onlyoffice.com/repo/debian bookworm main
Best regards,
Jean
hey @Jean
We suggest using the instructions for adding the repository provided in Help Center:
https://helpcenter.onlyoffice.com/installation/docs-community-install-ubuntu.aspx
Add ONLYOFFICE Docs repository:
echo "deb [signed-by=/usr/share/keyrings/onlyoffice.gpg] https://download.onlyoffice.com/repo/debian squeeze main" | sudo tee /etc/apt/sources.list.d/onlyoffice.list
Hello @Nikolas ,
Thank you for your answer.
I tried this repo first indeed, but I encountered a broken dependency, that’s why I wondered if a bookworm repo existed. The dependency error is:
libx11-xcb1 : Depends: libx11-6 (= 2:1.8.4-2+deb12u1) but 2:1.8.4-2+deb12u2 is to be installed
Note: I have Nextcloud already installed on this machine (nothing else).
Regards,
Jean
We usually recommend to use separate clean server for Document server installation.
It’s necessary to avoid dependency and port conflicts…
