Data validation not working on iOS
ONLYOFFICE Mobile: Documents/ Sheet
Do you want to: Report a bug
Steps :
  1. I have created a spreadsheet in which there is a data validation (dropdown list)
  2. I open the document on the iOS app
  3. there is no dropdown list button
    the data validation is working though as this not possible to input value other than those in the list.
Device: iPad 6th gen
OS version: iPadOS 16.4.1
App version: 7.3.3.53
Mode: Connect to Cloud & On Device
Browser version (for Web editors): Chrome 113.0.5672.63
Hello @iraza
If it’s possible, please provide us with a test file, where the issue reproduces. We’ll check it out.
please find a file enclosed : WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
As you can see in the screenshot, on the iOS app there is no dropdown button although the data validation is in place (you can only input manually “oui” or “non”).
As per the desktop version, we should be able to select the possible value
Thank you, we’re checking the situation.
Hello @iraza
We added your request to internal tracksystem. We have started working on it.
Unfortunately, there’s no DropDown list view on iOS at the moment.
