Custom Style applied in the Table of Contents
Do you want to: Report a bug / Ask a how-to question
For feature suggestions, describe the result you would like to achieve in detail:
1. This question arises from my tests with the Custom Heading described in this post. (I’m using the same styles generated by the document builder script provided in that post.)
How can I apply custom styling to the Table of Contents? I haven’t found any guidance on this in the documentation. My goal is to achieve a style similar to the one shown below:
I’ve observed that the Table of Contents doesn’t inherit the custom styles used in the header paragraphs.
2. Additionally, while reviewing the documentation and testing this method, I noticed that the TOC settings do not recognize the custom styles. Instead, they appear as “undefined.” For example:
It seems the TOC does not automatically apply the styles defined for the headings.
Script used:
// create a text document file in the .docx format with ONLYOFFICE Document Builder
builder.CreateFile("docx")
var oRun = oParagraph.AddText("Conteúdo");
oParagraph.SetBold(true);
oParagraph.SetFontSize(32);
oDocument.Push(oParagraph);
var aTocStyleLvl = [{Name: "Heading 1", Lvl: 1}, {Name: "Heading 2", Lvl: 2}];
var oTocPr = {"ShowPageNums": true, "RightAlgn": true, "LeaderType": "dot", "FormatAsLinks": true, "BuildFrom": {"StylesLvls": aTocStyleLvl}, "TocStyle": "current"};
oDocument.AddTableOfContents(oTocPr);
//---------------- Create the custom style to use in sections titles ----------------//
var oNumbering = oDocument.CreateNumbering("numbered"); // This need to be created here for the use of the section components
var oNumLvl0 = oNumbering.GetLevel(0);
var sFormatString = "%1";
oNumLvl0.SetCustomType("decimal", sFormatString, "right");
var oNumLvl1 = oNumbering.GetLevel(1);
var sFormatString1 = "%1.%2";
oNumLvl1.SetCustomType("decimal", sFormatString1, "right");
// Heading 1
var oHeadingLvl1Style = oDocument.CreateStyle("Heading 1", "paragraph");
var oTextPr = oHeadingLvl1Style.GetTextPr();
oTextPr.SetBold(true);
oTextPr.SetColor(0, 0, 0, false);
oTextPr.SetFontSize(28);
oTextPr.SetFontFamily("FreeSans");
var oParaPr = oHeadingLvl1Style.GetParaPr();
oParaPr.SetOutlineLvl(0);
oParaPr.SetNumPr(oNumbering, 0);
// Heading 2
var oHeadingLvl2Style = oDocument.CreateStyle("Heading 2", "paragraph");
var oTextPr = oHeadingLvl2Style.GetTextPr();
oTextPr.SetFontSize(24);
var oParaPr = oHeadingLvl2Style.GetParaPr();
oParaPr.SetNumPr(oNumbering, 1);
oParagraph.AddText("Heading 1 title (generated)");
oParagraph.SetStyle(oHeadingLvl1Style)
oParagraph.SetNumbering(oNumLvl0);
oParagraph.SetIndLeft(550);
oParagraph.AddText("This is some demonstrative paragraph just to fill out the page.");
oParagraph.AddText("Heading 2 title (generated)");
oParagraph.SetStyle(oHeadingLvl2Style)
oParagraph.SetNumbering(oNumLvl1);
oDocument.UpdateAllTOC(true);
// save the resulting text document as a file in the .docx format with the 'example.docx' name
builder.SaveFile("docx", "example.docx")
// close the text document file and finish work with ONLYOFFICE Document Builder
builder.CloseFile()
DocumentBuilder version: latest
Installation method: Downloaded the package from the official page and installed it using sudo dnf install <package name> .
OS: Rocky Linux 9 in a docker container
Hey @mrmikept :wave:
Thank you for reporting this issue!
We will need to test the problem further to better understand it. As soon as we have any updates or a solution, we’ll make sure to notify you right away.
Hi @mrmikept :slight_smile:
Apologies for the long wait — only now we were able to take the time to review this.
We have created a bug report for the described scenario:
  • Issue with displaying/applying custom styles in the Table of Contents.
  • Custom styles appearing as “undefined” in the TOC settings.
We appreciate your feedback and will keep you updated if there are any developments. Let me know if you have any other questions.
Sorry for delay response.
