Do you want to: Report a bug / Ask a how-to question
I attempet making the suggestiong made by @Constantine in this post, to create a custom Heading
styling with a custom Numbering
I attempted to create a custom Numbering
and apply it to the Heading 1
, Heading 2
and Heading 3
. However, I noticed that while Heading 1
works as expected, the Heading 2
and Heading 3
styles are being created without the Numbering
for some reason. Am I missing something?
In the previous image, you can see that the headings 1, 1.1, 1.1.1, 2, and 2.1 were generated using the document builder. However, when I try to use the newly created styles in the document editor, the numbering in Heading 2 and Heading 3 does not appear.
Interestingly, in the document editor’s styles menu, the numbering is visible in the name of the Heading 1
Style, barely visible although. This behavior, however, does not apply to the other headings for some reason.
I’ve noticed that in the document editor, you can simply select the text and update the style using the selection, as shown in the first image:
This action effectively updates the style with the numbering, as demonstrated in the second image:
If there are no errors in my document builder script, and if it not possible to create the Heading 2
and Heading 3
with Numbering in a custom Style, is it possible to perform this style update programmatically using the document builder?
Below, you’ll find a document builder sample along with the generated document:
// create a text document file in the .docx format with ONLYOFFICE Document Builder
builder.CreateFile("docx")
//---------------- Create the custom style to use in sections titles ----------------//
var oNumbering = oDocument.CreateNumbering("numbered"); // This need to be created here for the use of the section components
var oNumLvl0 = oNumbering.GetLevel(0);
var sFormatString = "%1";
oNumLvl0.SetCustomType("decimal", sFormatString, "right");
var oNumLvl1 = oNumbering.GetLevel(1);
var sFormatString1 = "%1.%2";
oNumLvl1.SetCustomType("decimal", sFormatString1, "right");
var oNumLvl2 = oNumbering.GetLevel(2);
var sFormatString2 = "%1.%2.%3";
oNumLvl2.SetCustomType("decimal", sFormatString2, "right");
// Heading 1
var oHeadingLvl1Style = oDocument.CreateStyle("Heading 1", "paragraph");
var oTextPr = oHeadingLvl1Style.GetTextPr();
oTextPr.SetBold(true);
oTextPr.SetColor(0, 0, 0, false);
oTextPr.SetFontSize(28);
oTextPr.SetFontFamily("FreeSans");
var oParaPr = oHeadingLvl1Style.GetParaPr();
oParaPr.SetOutlineLvl(0);
oParaPr.SetNumPr(oNumbering, 0);
// Heading 2
var oHeadingLvl2Style = oDocument.CreateStyle("Heading 2", "paragraph");
var oTextPr = oHeadingLvl2Style.GetTextPr();
oTextPr.SetFontSize(24);
var oParaPr = oHeadingLvl2Style.GetParaPr();
oParaPr.SetNumPr(oNumbering, 1);
// Heading 3
var oHeadingLvl3Style = oDocument.CreateStyle("Heading 3", "paragraph");
var oTextPr = oHeadingLvl3Style.GetTextPr();
oTextPr.SetFontSize(22);
var oParaPr = oHeadingLvl3Style.GetParaPr();
oParaPr.SetOutlineLvl(2);
oParaPr.SetNumPr(oNumbering, 2);
// Adding sections
oParagraph.AddText("Heading 1 title (generated)");
oParagraph.SetStyle(oHeadingLvl1Style)
oParagraph.SetNumbering(oNumLvl0);
oParagraph.SetIndLeft(550);
oDocument.Push(oParagraph);
oParagraph.AddText("Heading 2 title (generated)");
oParagraph.SetStyle(oHeadingLvl2Style)
oParagraph.SetNumbering(oNumLvl1);
oParagraph.AddText("This is some demonstrative paragraph just to fill out the page.");
oParagraph.AddText("Heading 3 title (generated)");
oParagraph.SetStyle(oHeadingLvl3Style)
oParagraph.SetNumbering(oNumLvl2);
// save the resulting text document as a file in the .docx format with the 'example.docx' name
builder.SaveFile("docx", "example.docx")
// close the text document file and finish work with ONLYOFFICE Document Builder
builder.CloseFile()
HeadingExample.docx (26.3 KB)
DocumentBuilder version: latest
Installation method: Downloaded the package from the official page and installed it using sudo dnf install <package name>
OS: Rocky Linux 9 in a docker container
