Cursor misalignment issue
Cursor misalignment issue in document editor causing incorrect text edits and difficulty in selecting text.
Action Performed By User:
User opened the contract editor and attempted to edit or comment on a document.
Expected Result:
Edits and text selections should occur exactly where the cursor is placed.
Actual Result:
Edits are being applied to a line above or below the intended line, and text selection is inaccurate.
Replicable:
Yes, the issue occurs consistently when editing or selecting text in the contract editor.
Document Server version: 8.2.2 (docker)
installation guide that you used as well):
OS: Windows
Browser version: 136.0.7103.93
Hello @ketul.provakil,
Does the issue occur with all documents or only with a particular one?
Does the issue occur in all browsers?
Also, please note that Docker installation on Windows OS is not officially supported. You can refer to the Docker installation requirements here:
(OS: amd64 Linux distribution with kernel version 3.10 or later)
This issue occur with all documents and browers for some users.
We have installed docker on ubuntu, user is using windows OS.
Please update to the latest 8.3.3 version and check if the issue is reproduced there, we haven’t been able to reproduce the issue on the latest version so far. If the issue reoccurs on version 8.3.3, please provide more precise steps to reproduce it.
