Cursor error when entering text into a spreadsheet
Hi!
When working with tables. If the text in a cell is typed in several lines (alt+enter) and the cell is centered, then the cursor moves to the wrong place to insert the text, and when typing it moves faster, in general, this is a bug that creates inconvenience. It would be great to fix this. This problem is definitely over 6 months old. I’ve watched this on multiple devices, and the app has been updated. Windows 10 and 11.
Hello @fixonu4,
Please provide the screen recording showing the steps of issue reproduction
I tried to reproduce the problem as clearly as possible.
Yet we haven’t been able to reproduce the issue on our side for now (using Desktop Editors 8.3 on Windows 11), please provide the original file that you used for the reproduction
In the latest update, the problem was fixed, but not completely. Now the cursor follows the text, but after alt+enter it is placed at the edge, although the alignment is centered. And only after you start typing the cursor moves to its place.
We are currently analysing, thank you for sharing
The above-described problem is related to the known bug, I have added your request to it. We will be working on it, thank you for sharing!
