Need dedicated support? Click here
Click here
CRM history import
Hi everyone!
I’m a bit confused about CRM data import/export. When I export all data to ZIP-archive there is a History.csv file which contains a pretty useful information about the interaction with contacts. But all of a sudden I can’t see any way to import this file back to CRM. If can export it, aren’t I supposed to be able to import it back?
So, my question is, am I able to transfer this dataset between two servers without access to CLI?
Thanks in advance!
Hello @kravtsov
We are checking the situation. I will update this thread when we have something to share.
Update:
We have started working on your suggestions. We are planning to implement import of History and Products and services files. Thank you for pointing us to this situation.
Thanks a lot. I’m going to be looking forward to this feature.
