I want to create a document using docbuilder api by passing the docbuilder script as string instead of the url location of the file. Is this doable?
Hello @anup
Unfortunately, Document Builder cannot operate without .docbuilder script.
I have the following builder script in a file:
builder.OpenFile(Argument["inputfile"])
oDocument.SetFormsData(Argument["data"]);
builder.SaveFile("docx", Argument["outputfile"]);
builder.CloseFile();
Can OpenFile and SaveFile receive arguments ? It does not seem to work for me. Is there any other way to pass arguments to OpenFile and CloseFile ?
You should use jsValue
instead for arguments that are passed to the builder methods as per 3 item of this article, for instance, like that:
var sDocURL = Argument["DocURL"];
builder.OpenFile("jsValue(sDocURL)");
var sDocName = Argument["DocName"];
builder.SaveFile("docx", "jsValue(sDocName)";
Thanks. It worked. I am actually trying to use this script to dynamically fill templates and generate a document from a python backend. Can I do something like this using automation api ? I can not find any documentation about the API endpoints for automation API but only its methods.
Automation API allows interacting with the editor from outside. Please see an example here:
It generally has the same interface as plugins, so you are generally connecting to the editor:
Please note that Automation API is available in Developer Edition of ONLYOFFICE Docs only.
