Create Checkbox in spreadsheets?
Trying to figure out why i can’t create checkboxes on spreadsheets but can on the new “word” document. Just doens’t make sense as to why i can’t on spreadsheets. Am i missing something?
Hello @alishadfar
If I understand you correctly, you are referring to Form Controls. Unfortunately, Form Controls are not yet supported in our editors.
Let me know if I’m mistaken. If I am, please provide a link to the documentation about checkboxes and how to add/create them in other editors.
Hello. You’re correct that i’m referring to “Form Controls.” I was trying to setup a Task List where you can check the box and strikesthrough text. I have the logic/formula working (instead of a checkbox i’m using True/False)…would look much cleaner if we were able to use a checkbox. I appreciate your response and hope you guys add that feature in the near future. Thank you.
