Hi,
I’m doing something wrong but i can’t figure it out. Can you help me?
i have a problem with onlyoffice (installed in docker) and alfresco (installed locally).
I have no problem editing the files from alfresco share (the “edit in only office” works well and either the options are well formed, i can regularly edit the documents in this way from the share page). I have no problem with the onlyoffice example too.
I have a problem with a custom view (javascript e html) where i want to show the onlyoffice editor.
The steps that i’m doing are:
- first i’m doing the prepare
$.getJSON(URL+“parashift/onlyoffice/prepare?nodeRef=workspace://SpacesStore/ECC&alf_ticket=TICKET_ECC”)
and this WORKS, i have the response with all the info that i need; - then i do this where res is the response from the prepare and testplaceholder is my html element where i want to show the onlyoffice editor
$.getScript(“http://localhost/web-apps/apps/api/documents/api.js”, function(){
new DocsAPI.DocEditor(“testplaceholder”, res
if i go to the url http://localhost/web-apps/apps/api/documents/api.js i can see the api so this is correct, the problem is in in the DocEditor at the line
target.parentNode && target.parentNode.replaceChild(iframe, target);
and then my alfresco says
Could not resolve view with name /documenteditor/main/index.html
