Do you want to: Suggest a feature / Ask a how-to question
DocSpace version: 2.5
Type of installation of the Space (docker, deb/rpm, exe, )
OS: windows 11
Is it possible to copy documents from Docspace to the clipboard? To immediately insert files into other applications. It is the documents that do not link to the file.
Hello @Nikita
Sorry for the late reply. We need some time to discuss this scenario. I will update this thread as soon as possible.
Hello @Nikita
Unfortunately, there’s no way to copy files to clipboard and to paste them to an external app. However, we have implemented internal clipboard between rooms on the portal itself. You can select a file > copy > paste it to another room.
