Hi. I am new with onlyOffice Api. I previously used Aspose HTML to DOCX conversion, where images that appeared normal within the HTML are showing up in a smaller size in OnlyOffice.
Here’s the conversion query I’m using:
public boolean convertHtmlToDocx() {
try {
String onlyOfficeUrl = "http://localhost:8500/converter";
Map<String, Object> requestBody = new HashMap<>();
requestBody.put("async", false);
requestBody.put("filetype", "html");
requestBody.put("key", UUID.randomUUID().toString());
requestBody.put("outputtype", "docx");
requestBody.put("codePage", "65001");
requestBody.put("title", "document.docx");
requestBody.put("url", htmlFileUrl);
String token = generateToken(requestBody);
HttpHeaders headers = new HttpHeaders();
headers.set("Authorization", "Bearer " + token);
headers.setContentType(MediaType.APPLICATION_JSON);
HttpEntity<String> request = new HttpEntity<>(new JSONObject(requestBody).toString(), headers);
RestTemplate restTemplate = new RestTemplate();
String response = restTemplate.postForObject(onlyOfficeUrl, request, String.class);
JSONObject jsonResponse = new JSONObject(response);
String url2 = jsonResponse.getString("fileUrl");
ResponseEntity<byte[]> fileResponse = restTemplate.getForEntity(url2, byte[].class);
byte[] docxContent = fileResponse.getBody();
String outputPath = "C:/Users/user/Desktop/outlook-images/test.docx";
Files.write(Paths.get(outputPath), docxContent);
System.out.println("Fayl yaradıldı: " + outputPath);
return true;
} catch (Exception e) {
System.out.println("Error: " + e.getMessage());
return false;
