Need dedicated support? Click here
Click here
Conversion API From Txt escaping as HTML
Using the conversion API with txt files to any outputtype, creates a resulting file with input interpreted as HTML.
For Instance a text file containing
 < ' > <b> bold</b>
will output
&lt; &apos; &gt; &lt;b&gt; bold&lt;/b&gt;
Options used :
filetype = “txt”,
outputtype = “pdf”
Best,
Hello @humbol
Please try adding the file encoding parameter codePage to the conversion request body with corresponding encoding.
codePage - Defines the file encoding when converting from csv or txt format.
If the issue is still reproducible that way please provide version of Document Server and installation type (docker, DEB/RPM, exe).
I have the issues on version 7.3, either desktop or web version.
Just try open up a txt file with ampersand or html special characters(< & >, etc) and they will be escaped as if it was an html file instead
I wasn’t able to reproduce the issue.
I’ve created a TXT file and pasted your example there:
Desktop Editors 7.4 opened it without any issue:image
I just tried with the version 7.4 and it is working well, I guess it is just linked to 7.3.
thanks
For sure it is. I’m glad to hear that it works now.
