Consultation on plugin usage issues
1.using Document Server
2.the version is 8.2.2 (build:22)
When using “window.Asc.plugin.callCommand(() => {});” in the plugin, calling “Document.InsertContent、Paragraph.InsertParagraph …(for count > 5)” internally will result in an error if “callCommand → isCalc is true”
Hello @zazatyty
Please update your instance to the actual version 8.3 and check the situation again.
Okay, I’ll give it a try
Looking forward to your feedback.
