Connection to Workspace document server
For feature suggestions, describe the result you would like to achieve in detail:
Community Server/Control Panel version: Latest
Type of installation of Workspace (docker, deb/rpm, exe)
OS: Docker
Browser version: Ltest firefox-chrome
Hello, I have question about connecting to a workspace installation from outside service.
So, I have working installation of Workspace instance of onlyoffice on onlyoffice.mydomain.com and I need the ability to connect to this instance from another service/sw(Filerun) running somewhere on internet to by abble to use document-server editing documents feature. I have JWT, but Im not abble to connect to this service on my domain:
OO running in docker:
How do I resolve this?
Thx.
Hello @OnOoflrFice99
I believe that separate Document server integrated with Filerun is the best option. However, probably connecting Filerun as WebDAV folder to Workspace should work too:
If you still need to use Document server from Workspace in the Filerun integration, probably it’s better to contact colleagues of mine to discuss possible options: Get dedicated support
You are right, I already did that. Thx.
