Am using OnlyOffice document server on my windows locally, everything was working pretty fine until after i uninstalled it because of space issue then later on went back to install it after some time , then I started facing this issue
“Connection has been interrupted pleas reload page”
picture of error attached below
i have uninstalled and installed again and again to try and fix the error but no solution, please help out.
Please provide Document Server logs: /var/log/onlyoffice/documentserver (for Docker inside the container)
Windows: C:\Program Files\ONLYOFFICE\DocumentServer\Logs
Hello support,
Good day, thank you for your response and sorry for the delayed reply
the Logs folder has four different directory
converter
docservice
example
nginx
which of them am i sending over please,
thank you.
@hanson4christ Please send all of them (as an archive file, for example)
