I’m trying to set some conditional formatting with a formula in which I use decimal values (i.e. 1,3 and 0,05).
In the pop-up menu I input the formula this way :
=G2<>ARRONDI.AU.MULTIPLE(F2*1,3;0,05)
But as soon as I close the pop-up menu with the OK button and reopen the menu the formula as changed to :
=G2<>ARRONDI.AU.MULTIPLE(F2*1;3;0;5)
the commas got changed to semicolons and a zero is missing. The formula is now invalid
I could make this work by computing the formula in another column and then comparing the value but I would preffer to do everything at once with conditional formatting
Hello @DeKaZedd
As I can see the formula spelling is in French. When using File tab > Advanced Settings > Regional Settings > Formula language > French the formula works as expected:
If English is used as Formula language instead and formula spelling remains as on your example, then it prompts #NAME?
error which is expected. English form of this formula is:
=G2<>MROUND(F2*1,3;0,05)
Please make sure that you are using Formula language in Advanced Settings corresponding to formula spelling.
Thy but this was not my issue, I really think there’s a bug cause I’ve no problem with LibreOffice (Excel not tested).
I can perfectly use this formula inside a cell but when using it for conditional formatting, the commas are converted to semicolons upon validation, thus rendering the formula invalid.
I tested another formula containing a decimal value and the comma got converted even wierder
formula input for conditional formatting : =S2=(R2*0,5)
formula when reopening the conditional formatting rule : =R2*0=(5)
I can only compute the test in another column and use the boolean result as input for the conditional formating for those formulas to work correctly.
I’m workin on v8.0.1.31
Please provide a video demo or step-by-step scenario on how to reproduce the issue as I seems I am missing something and still unable to reproduce it. That’d be much appreciated.
https://www.swisstransfer.com/d/7dd03efc-6c4b-4621-92ed-49593af6eea0
There, I think I understood were the bug(s) comes from.
The thousands and decimal separators differs depending on the regional parameters and those changes does not affect formulas inside conditionnal formatting (where the formulas always use english separators not the user’s ones). We can also see in my video that when switching regional parameters, the formulas inside the sheet were modified but not the ones in the conditional formatting rules.
Thank you for the detailed video. We are checking the situation, I will provide an update when results come up.
We were able to reproduce the issue, the bug based on received results was registered. Thank you for reporting this issue.
