Chinese date formats are less in oform
I find Onlyoffice desktop support Chinese date format ,like YYYY/MM/DD, YYYY年MM月DD日. But in oform, the date control do not have these formats. Can you please add those Chinese date formats. In China, we also use this format, for example ‘二〇二三年七月二十日’, it is 2023/7/20. It likes YYYY年MM月DD日, but YYYY MM DD are in Chinese number:
0=〇
1=一
2=二
3=三
4=四
5=五
6=六
7=七
8=八
9=九
It is better to add this format.
OS version: windows11
Hello @Li.fe
Can you elaborate on this? For Content Controls you indeed can change the date format manually via Content Control settings. So you want to have similar possibility with the OFORM date and time fields?
I can elaborate on this. Tell me how to do it.
I’d like to inform you that here is no need to elaborate on this anymore.
We received the same request to add Chinese date formats to the Date and Time field in Forms from other source and have registered it. I’ve added your request to this suggestion.
I just install DesktopEditors_x64 7.5, And i find date format in Data & Time form component does not change. So when do you update it?
Unfortunately, this suggestion is not implemented yet. Once I get any news in this regard, I will notify you.
thanks!it is simple,hope to get it soon.
