Changing fonts of LaTeX equations
I am using OnlyOffice 8.2.0 to create a .docx document with LaTeX equations. I can change font size, but when I attempt to change the font itself, it doesn’t take effect. How can I change the fonts inside LaTeX equations?
Hello @Joshua
For equations default font Cambria Math is used and it cannot be changed pretty much just like in other processors.
Recently an enhancement suggestion was registered to implement possibility to use other “math” fonts for equations, so I am adding your query to it.
Hello @Constantine,
Thank you for your explanation. Just to confirm, is this limitation in MS Word as well? I don’t want to install Word just to see the same limitation.
It is, as far as I know. Maybe different font used, but the absence of possibility to change equation font persists.
Thank you. I will stick to LaTeX then.
