Change listen port
Do you want to: Suggest a feature / Report a bug / Ask a how-to qluestion
Document Server version: Doc community edition
Type of installation of the Document Server (docker, deb/rpm, exe) RPM
OS: Centos 9 stream
Browser version:
I only have 1 public IP and need serve with nextcloud also. Looking of information change the onlyoffice listen port. To non 443 port an Maintenace secure connection
You can change the port in ds.conf which can be found here: /etc/onlyoffice/documentserver/nginx/ds.conf
After that remember to run systemctl restart nginx command.
Thank reply. fixed
I’m glad to know the issue is resolved.
