I’m using OnlyOffice Desktop v6.4.1.46 for windows. I’m having trouble with adding new fonts.
Onlyoffice (downloaded from your official site) and my system are installed on C: (i have multiple drives).
My fonts are in C:\Windows\Fonts and they are visible in other text editors. But they do not appear in the fonts dropdown in OnlyOffice document (or any other OnlyOffice editor).
Is there any specific operation i’m missing to allow OnlyOffice to access my installed fonts ?
Just to be clear i can’t see any of the fonts i installed, not just one in particular. However here are some of the ones i’d like to use in Only office. (i don’t know how to join a font file to my reply, however i can find where i downloaded them).
Unfortunately, we are unable to reproduce this issue. Could you provide us with a step-by-step video example of you reproducing it from scratch using one of the fonts you mentioned?
I’m affraid i can’t capture my screen although i can provide screenshots and a step by step description of what i did.
First i made sure Only office is closed, then downloaded the font from dafont (Pirate scroll for instance), then extracted the font in my download folder using winrar. Double clicked it and then clicked Install (“Installer” since my computer is in french, if it matters)
Then launched OnlyOffice, created a new document in the “create new” section. Finally i check in the fonts dropdown and the font isn’t there.
Hi, I have the same issue on a windows 10 computer, and is in french too.
Try to reboot, try to delete de appdata onlyoffice folder, the new fonts are not shown in onlyoffice.
Same problem.
App: ONLYOFFICE Desktop Editors version 7.1.1.57 64bit (updated regularly from some older unknown version).
PC System: Windows 10 Pro 21H2, i7 CPU, 32Gb ram.
Followed guide here.
Installed this font as per guide.
Closed program, font did not appear in dropdown list. Rebooted, font still did not appear.
Font appears in ALL other applications currently installed!
I uninstalled app and checked delete all settings then reinstalled the app.
Still no new font
I created a docx document in LibreOffice Writer with text using new font and saved document. I then opened in OnlyOffice Editor but text is displayed in default font. Font name appears in dropdown list window but disappears after changing font?
Works in MS Word, LibreOffice, OpenOffice, Softmaker Textmaker.
Font problem also exists in spreadsheets.
I found the issue or at least how to get the program to see new fonts. When you open c:\Windows\Fonts or control panel/fonts and either drag the font file into the folder or open the font file and click install, the font file is actually installed/copied to c:\Users\username\AppData\Local\Microsoft\Windows\Fonts. If the font file is copied to c:\Windows\Fonts using admin shell, then it appears in the dropdown!
Recently did a complete OS re-install and hoped it would clear up this problem of ONLYOFFICE Desktop only capturing the Microsoft’s default system fonts. I’ve reviewed all the comments on this thread and none of the m address my problem.
None of these other applications I use ― Affinity Publisher 2, Affinity Designer 2, Affinity Photo 2 and the new release FreeCAD 1.0 have a problem seeing these additional fonts I’ve installed, which are mostly Google Fonts matching those used on my website, Ubuntu Sans and Passero One.
I’ve previously used Microsoft 365 and LibreOffice, which have a less sophisticated, older Ui designs than ONLYOFFICE Desktop, but do not have any issue presenting my installed fonts.
Here are my basic system specifications and I have tried ONLYOFFICE settings and can’t force it to display my fonts.
Hello @Muiren
Sorry for the late reply.
Could you please share the fonts that installed in your Windows OS, but don’t appear in the Desktop Editor? We will check the situation.
Same problem today. On MAC OS 15.5 with OnlyOffice 8.3.3
Just discover OnlyOffice and try it, but my font doesn’t appear on the list.
I make document in English and Traditional Chinese.
NOTO SANS TC only appears in thin style
I can see the font from a document I created with libreOffice, but If I want to reuse it in OnlyOffice I can’t in the same document.
So I suppose it’s because a part of the font style are installed in my profile and another part are in the system.
I hope it will be corrected on the v9.
Hi @Constantine , Just download the font from here , double-click on .ttf and installed with Apple Font Book.
I checked: it’s in /Library/Fonts/ system directory (not in /Users/[user]/Library/Fonts)
But I don’t think it is the problem, because I have font in my home directory that I can successfully access with OnlyOffice. All are .otf
I think maybe it’s because it’s Chinese traditional characters. For example, I have Vietnamese fonts I can not see in onlyOffice… i don’t know
