ONLYOFFICE Workspace 12.5: enhanced security, optimized document management, Dark theme, and more
ONLYOFFICE Workspace 12.5 released
Can't run a macro twice
Problem: I can’t run a macro twice.
Document Server version: Spredsheet 7.0.1
Installation method: docker
OS: Windows
Browser version: Chrome 108
So, I want to make a simple button to change the column width. Works fine for the first time, but when I change the width manually and run the macro again it should resize it again but nothing happens.
Same happens when I use the isHidden(true) command.
Basically, what I need is to hide some columns with a click of a button and show them again with another button. The best option would be only a toggle button but two buttons are fine too.
Macro:
(function()
    Api.GetActiveSheet().SetColumnWidth(5, 25);
Thanks.
Hello @Marc
Please not that you are using an outdated version 7.0.1 of our editors, the actual version is 7.2.1. On the actual version I wasn’t able to reproduce described issue.
I recommend you to update the Document Server and check the situation again.
