Cannot insert more than one line with "Insert above"
Windows 10 32 bit, Only Office 8.3.3, Intel Core i5-2400 3.10GHz, xlsx-file
If I want to insert multiple lines, select multiple lines with the mouse, and then choose “Insert above,” only one line is inserted. Even if I use “Ctrl Shift +” instead, only one line is inserted, but it’s at least a bit faster.
Hello @gustavo19
I’ve just tested the scenario and lines are inserted correctly. Selecting several rows and either using Insert row above from context menu or using Ctrl+Shift++ results in insertion of the same amount of rows as selected. Can you record a video to demonstrate your actions?
“Sorry, new users can not upload attachments.” I figured it out: You can’t select lines individually, but instead use the shift key to select them. Thanks!
I am glad to know that you’ve figured it out. Closing topic as solved.
