Cannot connect Docserver to external PostgreSQL DB over LAN
I have a ProxMox homeserver running multiple containers:
Nextcloud = 102 = 192.168.2.63
OnlyOffice = 104 = 192.168.2.65
PostgreSQL = 105 = 192.168.2.66
All containers are unprivileged Debian12 stable images.
Nextcloud and OnlyOffice are correctly configured and successfully web-facing.
Currently OnlyOffice is using the PostgreSQL db installed with the AIO script within the same CT but I am migrating all services to the dedicated PostgreSQL CT 105, and herein lies my problem - no matter what I try, I cannot point the docserver to my Postgres CT.
I have created the user, database and password within Postgres and tested connection from OnlyOffice with:
psql -h 192.168.2.66 -U onlyoffice -d onlyoffice
which successfully connects to the database, as checked with:
SELECT datname, usename, client_addr, client_port, state
FROM pg_stat_activity
WHERE client_addr IS NOT NULL;
which returns:
datname | usename | client_addr | client_port | state
onlyoffice | onlyoffice | 192.168.2.65 | 51232 | idle
(1 row)
sql block in local.json:
   "sql": {
    "type": "postgres",
    "dbHost": "192.168.2.66",
    "dbPort": "5432",
    "dbName": "onlyoffice",
    "dbUser": "onlyoffice",
    "dbPass": "REDACTED"
I even attempted to pass environment variables before running the install:
export POSTGRESQL_SERVER_HOST=192.168.2.66
export POSTGRESQL_SERVER_PORT=5432
export POSTGRESQL_SERVER_DB_NAME=onlyoffice
export POSTGRESQL_SERVER_USER=onlyoffice
export POSTGRESQL_SERVER_PASS=REDACTED
This had zero effect and the default arguments were passed upon installation.
I cannot find documentation on this specific issue or bug ANYWHERE, so if anyone could help that would be amazing, as at the moment it’s looking like I might have to spin up a docker container to force the variables to pass, which I really don’t want to do on this install!
Hello @Guacamole4323
Take a look at logs of Document Server and share any records with status [ERROR]. Logs are located in /var/log/onlyoffice/documentserver directory (same path in the container if installed with Docker).
Do I understand correctly that the installation type of Document Server is Docker?
