const docEditor = new DocsAPI.DocEditor('monitorOffice', config);
报错了
Hello @balabalabal
Sorry, we don’t have ready-to-go example for your request. But I believe that all things should run smoothly. As far as I know Vue framework is used with Java projects usually. Probably this Java example of integration will help you in your research: ONLYOFFICE Api Documentation - Example
If it doesn’t help, please provide us with issue details.
看起来像是你的参数match是空的,或者你这个页面有参数叫match被使用了,但是没有被定义(为空)
