Can ONLYOFFICE Connector for Confluence continue using after Confluence Server EOL, 2024/2/15?
Hello @AnitaChen
Basically, if the version of the connector app supports specific version of the Confluence, then there should be no trouble. For reference, you can check out versions compatibility here:
Hi Constantine,
Thank you for your reply.
Noted that if the version of app supports the version of confluence, we can continue using it.
