Bulletpoint-wise animation of Textblocks
I am just migrating von MS office to Only office, facing severe issues with bulletpoint-wise animation of text-blocks. (workaround like 10…15 years ago in MS Office: let white boxes disappear step by step …)
It seems OO is not supporting this imho important feature - or only partially as it is correctly show in speakers view.
Hello @ProfMat
Please provide more context to the situation you are describing. Are you referring to presentation editor animations? What is the exact scenario to reproduce mentioned behavior? If possible, please share a test file for analysis of the issue.
Additionally, please specify product that you are using and its version.
I am using Version 8.3.2.19 (x64 exe) on Windows.
The scenarios is quite simple:
  • standard text field
  • list of text items (like this list here)
  • goal: let the text appear stepwise (bullet point by bullet point)
status quo:
I can only define an animation for the entire text field, not for each individual bullet point
Unfortunately I am not allowed to upload a demo-file.
yes - it is about the presentation editor.
Thanks for the reply and all information.
You can upload it to any cloud storage and share a link.
