Hello
Here is what I see get:
At first, changing font size is acting ok.
But, after a while (or a certain size), it’s making none-sens:
- the bullets have a size way more important than the text
- space btw the bullet and the following text is not the same depending on the line
Note that:
- I first encountered an abnormality with the space btw the bullet (b.) and the following text. I was not using huge font sizes, just regular sizes.
- when I created the test file, at first everything was normal
but then… you can see what happened.
weird spacing.docx (26.0 KB)
thanks for analysing it.
Hello @arcqus
We’ll look into your case. Once I have information on your situation, I’ll get back to you!
Thank you for providing a detailed description of the issue!
@arcqus
We have reproduced the issue you described and have created a bug report.
Thank you!
Hi @arcqus
I wanted to inform you that ONLYOFFICE Docs* v8.1.0 has been released, and the bug has been fixed.
For more details and the full list of new features in version 8.1.0, please refer to the changelog: Version 8.1.0 Changelog.
* The new version of ONLYOFFICE Desktop Editors (8.1.0) will be released within the next couple of days.
