Community Server/Control Panel version: Onlyoffice Groups (Community Server)
Type of installation of Workspace (docker, deb/rpm, exe): building form sournce
OS: Windows Server
Browser version: Chrome
I’m busy building OO Groups from source following this instrcutions:
When everything is compiled and built files are moved to C:\ONLYOFFICE folder,
The script that starts everything up (ManageServices.bat) has the following lines in it:
I modified the ASC.Web.Studio\web.connections.config file and mysql password field was empty, so I put in the password. That made a small progress. http://127.0.0.1/Wizard.aspx now opens up.
Hello @taran
We have found a bug in the described scenario. We are going to fix it with Community server v.12.6 release.
Thank you for pointing us to this situation! I will update this thread when we release v.12.6
If you do not have the time frame, can you give some clues on how to manually fix the issues? Because some of those services not starting up, I’m having issues where Documents do not work. I can not create a new document, I can not edit dample documents, it just throws 404 error Page not Found when I click on any sample document with the following linke: http://127.0.0.1/Products/Files/HttpHandlers/filehandler.ashx?action=download&fileid=2&version=1
We need some time to figure out if there’s workaround solution, while we are working on the v.12.6. I will update this thread as soon as we have checked it out.
