Build in Compresing Pictures Feature
Hi,
Could You consider adding Compressing Pictures Feature. In my opinion it’s pretty useful option in Microsoft Office, because it allows to quickly reduce the size of Presentation - thanks to that You can easily compress all of photos included in to document.
obraz
Do you want to: Suggest a feature
OS version: Windows 10
App version: 7.4.0.163
Hello @scorek1
Thanks for the suggestion. We will take a closer look at it and I’ll let you know the result.
I have found out that this suggestion has been already registered so we’ve added your request to it. Unfortunately, I cannot provide any approximate dates when this feature would be available in the editors.
