Bug report: spellcheck language selection
Hello, after selecting a spell check language, I can change the language in the document editor, but typing any character resets the language to my original language selection.
I am able to change this by restarting the app, but I work simultaneously in multiple languages, so this is a major annoyance.
I believe I found the same bug in ubuntu 20.04, but I dont have access to verify at this moment.
OS version: windows 10
App version: ONLYOFFICE Desktop Editors version 7.2.1.36 (x64 exe package)
Hello @jbj
To avoid problems with spellchecker language change you can set “Spelling language detection” setting to Disabled in the Settings menu of the application.
Hope it solves your problem.
thank you, this helped
