BUG Report in Presentation
OS version: Windows 11
App version: OnlyOffice 8 - Presentation - Desktop Edition
Since version 8, the transparency of a animated form is lost : ie. no more transparency when the animated form move into the page.
Please provide an original file with the animated form where the above-mentioned issue is reproduced.
As a new user I can’t send attachment. Can you give me an email where I can send the file. Thanks.
Now you should be able to attach files, please try once again.
EV1.pptx (1.1 MB)
This is a example file, I just keep only on page to show the problem, but it was the same for all other similar pages.
I set the opacity of the animation at 50% for example, but OnlyOffice keeps it at 100%, and set it back to 100% when the file is saved.
I notice this problem only with version 8.
Thank you.
Thank you for the provided file, we are currently analysing the issue, I’ll inform you as soon as there is news.
Hello, we have reproduced the above-mentioned issue and registered the bug in our bug tracker. I’ll notify you as soon as the version with the fix is released
