Bug in dragging/moving rows with shift
1
  1. Select a row you want to move
  2. Hold shift and drag the row
  3. Result: the row above is moved instead of the selected row
See in the attached gif; the “f” row is selected but the “e” row is moved.
OS: Fedora
App: OnlyOffice Desktop, version 8.1.0.169
Hello, we are currently analyzing the issue, please wait.
Hello, the above-reported issue should be fixed on the next update
Hello, the bug has been solved, but this cause a blank row.
Hello, received and currently analysing, thank you for sharing
Unfortunately, there is yet another bug which leads to this behavior, we have registered it and will be working on it, thank you for pointing out
the bug mentioned in this thread has been fixed in Document Server v.8.3.1. Please update your installation and double-check the result.
