In fields with list values, the arrow on the right side of the cell to open the drop-down menu no longer appears.
Now the only way to show the values is to right click on the cell and from the quick menu select the item “Select from the drop down menu”.
This slows down the sheet-filling operations.
Do you want to: Report a bug
DocSpace version: 8.2
Type of installation of the DocSpace (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS: Mac OS 15.0
