When opening options, in this case “Passcode lock” and “About”, I get a blank page for a split second and then it goes into the desired option. It should go into the desired option without showing the blank page. I don’t know does this happen when choosing other options outside of settings. I have named the video “blank page settings”.
Thanks
Device: Huawei P9 Lite
OS version: 7.0
App version: 7.5.1
Mode: On Device
Hello @nicesto
There’s v.7.5.0 in the provided video file. Would you mind checking that the situation reproduces on the latest version (v.7.5.1)?
Unfortunately, OO mobile app is not supported anymore on my phone, because my phone has Android version 7.0 and that is the last update for my phone and OO mobile app requires Android version 8.0. So, I can’t check does this issue still happen.
Thanks
Hello @nicesto
Understood. If you are able to check out described situation on another device, we will be glad for your report. I’ll keep this thread open just in case.
