Blank background appears inside onlyoffice for 3 seconds when exiting the program
  1. On already existing editor, when I just enter and after that I exit, the issue sometimes appears and sometimes exits normally.
  2. When I enter already existing editor to edit something and I save that, the blank background appears inside onlyoffice for 3 seconds and then the program exits.
  3. When I just enter any new editor, and after that I exit without saving, the issue sometimes appears and sometimes exits normally.
I have named the screenshot “blank background” for the issue.
Because of this issue, onlyoffice editor freezes sometimes (and it said “not responding”) and I had to use the task manager to exit out of a program. So, my computer did not froze, only the program. I have named the screenshot “not responding”.
I have named the issue “not responding”.
Now, the only time when the issue does not appear, when I enter already existing editor, and when editing something, and click close button, and I click No (so, not to save), the program exits normally without the issue. This also goes for, when entering an new editor, and I write something and click close button, and choose No (not to save), the issue does not appear.
OS: Windows 10 Pro; Version: 21H2
ONLYOFFICE Desktop Editors version: 7.2.1.36 (x64 exe package)
Hello @nicesto
To understand better the problem I ask you to provide us with your system characteristics.
Here they are:
Storage 1: Samsung 970 EVO 250GB SSD
Motherboard: Gigabyte B450M DS3H
Processor: AMD Ryzen 7 2700 Eight-Core Processor 3.20GHz
Storage 2: WD Blue 1TB 3,5" 7200rpm 64 mb SATA3WD10EZEX
GPU: GIGABYTE GV-N1660GAMING GTX 1660 6GB GDDR5 Gaming OC
RAM: G.skill 8GB Aegis DDR4 3000MHz CL16 F4-3000C16S-8GISIB
System type: 64-bit operating system, x64-based processor
We are checking the situation. I will let you know when there are any results.
Our team has created a bug report number 59400.
This is a major bug and we will try to release the fix in version 7.3
Hello @nicesto
We have released version 7.3.0 of Desktop Editors. Please update your current instance and check the situation.
I just want to let You know that all three issues are now fixed in version 7.3.0.
Thanks
Hello @nicesto
Thank you for providing a feedback.
Please do not hesitate to report any other issues that you face while working with our editors.
