Better arabic support for spreadsheets
First, i would like to see an option to orient sheets from right to left.
Second, I would like to see an option to render numbers in eastern arabic numerals
٠, ١, ٢, ٣, ٤, ٥, ٦, ٧, ٨, ٩.
Hello, RTL will be supported in Spreadsheet editor in our (8.2) version, the same as arabic numbers. This version planned for release in 4th quarter of 2024.
Hey Mr Ali , when i type arabic words in spreadsheet the direction of the letters still left to right . I use linux . I do not if the problem is in Windows as well.
Hello, You are right, that is because the Right To Left “RTL” function is not supported yet in Spreadsheet editor. It will be included in 8.2 version, as I mentioned earlier.
Hello @shagi
I’d like to inform you that we have just released new version 9.0 of Document Server that brings enhanced support RTL to the spreadsheet editor. Please update your instance and check out the situation again.
If you are using Desktop Editors, the update will be available shortly.
