Bengali language problem
Hi,
I don’t write in bengali language. Please solve it immediately.
Thanks,
Mehedi Hasan
Hello @mehedihasan
Please clarify your request. Do I understand it right that you want to add Bengal language support to Desktop Editors?
If I misunderstood your request, please clarify it.
Yes, you are absolutely right. Some key isn’t working properly for bengali keyboard layout.
Thanks.
We are checking the situation, I will notify you when we have something to share.
Hello @mehedihasan
Please clarify version of your Desktop Editors app. Also if it’s possible, please make a videofile while you are reproducing the situation.
Version 7.1.1.57
Version 7.1.1.57
Please update it to the latest version (v.7.2.1) and re-check the situation.
https://drive.google.com/file/d/1ECPeTqu0VrBphhV5oA9s4SQCGQp7Okk2/view?usp=drivesdk
https://drive.google.com/file/d/1E9xGuGCqkkdPqKKyZbejooB3rmCeNnWM/view?usp=drivesdk
https://drive.google.com/file/d/1E6gzyLCfI7rLxXsNTsdFEfTZZDX56pSh/view?usp=drivesdk
Please see the attached video. And please release update version for flatpak. My OS is fedora. Thanks
We are going to release flatpak version as soon as possible. I suggest you wait until we release v.7.2.1 on flatpak and double-check the situation. We added Bengali support with v.7.2 so you shouldn’t see any issues on current version.
If you don’t want to wait for flatpak release, you can install current version of Desktop Editors from repository: Installing ONLYOFFICE Desktop Editors to Red Hat, CentOS and derivatives - ONLYOFFICE
Thank you very much!
