Backup to Third party resource
Do you want to: Report a bug
DocSpace version: 2.6.1
Type of installation of the DocSpace (deb/rpm, exe, please point us to the installation guide that you used as well):
OS: Ubuntu 22.04
Browser version: Firefox 129.0 (64-bit)
Additional information:
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
When choosing backup option Third party resource it and going for Nextcloud is pops up to enter login and password but it does not have a space to enter URL.
And there is this error after entering login information because indeed i have not configued the url to my Nextcloud anywhere.
Am i missing something or you forgot to add it on the new update? On version 2.5.1 you could configure the URL.
On the docs Changing the DocSpace settings - ONLYOFFICE it says:
" You can also use Nextcloud, ownCloud, SharePoint, kDrive, or another WebDav service. Select the necessary service from the list, then click Connect. In the Connecting account window, specify the connection URL, your login and password, and click Save."
Hello @irdi
We are aware of this issue. Sorry for inconvenience.
Thanks for the reply.
Is there a way for users to track reported bugs and progress work on those?
We are always providing a notification once the issue is resolved and new version with fix is released.
Thanks, Constantine!
@Constantine It just happened again!
