Since the release of the newest onlyoffice update 2.5, we are experiencing problems with PDF files. Every time we open a pdf file, a copy of the file gets created automatically, overflowing the relevant folders with copies of pdf files.
This notification appears after open every pdf file, and the photo belows shows a folder with pdf copies:
Please provide a video showing the reproduction of the issue (with devTools Console and Network tabs open).
What is the method of DocSpace installation you used?
What is the OS?
The copies are created both on the desktop editor and online versions of docspace. I use Linux + brave browser, but the automatic copying happens on every other using it on whatever device since latest update Thank you
It is very useless to create a copy of a PDF file when you open it.
Furthermore the copy is created even when you use the preview command!
Please strip off this functionality as soon as you can or at least let the user to enable it.
Hello. I was wondering if there has been any update about this issue. An update has come out about PDF’s but I still see no way of turning off this issue. Is there no way to confirm the copy creation before creating it? our online Rooms are now full of copies which we must go back to delete often.
