Automatic backup on third party storage stopped triggering
Do you want to: Report a bug
DocSpace version: 2.6.1
Type of installation of the DocSpacedeb/rpm
please point us to the installation guide that you used as well): Installing ONLYOFFICE DocSpace using the provided script - ONLYOFFICE
OS: Ubuntu 22.04
Browser version: Firefox browser 129.0 (64-bit)
Additional information: Automatic backups was working just fine till 20th of August and it just stopped. No intervention was done on the setup or the services during this time.
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
The only logs which might be relevant is this
2024-08-23 11:01:31,103|ERROR|[121]|ASC.Core.Common.Hosting.RegisterInstanceWorkerService - Critical error forced worker to shutdown|System.Threading.Tasks.TaskCanceledException: A task was canceled.
   at ASC.Core.Common.Hosting.RegisterInstanceWorkerService`1.ExecuteAsync(CancellationToken stoppingToken)
2024-08-23 11:01:31,108|ERROR|[49]|ASC.Core.Common.Hosting.RegisterInstanceWorkerService - Critical error forced worker to shutdown|System.Threading.Tasks.TaskCanceledException: A task was canceled.
2024-08-23 11:01:31,169|WARN|[53]|ASC.EventBus.RabbitMQ.EventBusRabbitMQ - RabbitMQ: model is shutdown: (null)|System.Exception: AMQP close-reason, initiated by Application, code=200, text='Goodbye', classId=0, methodId=0
2024-08-23 11:18:25,164|ERROR|[64]|ASC.Core.Common.Hosting.RegisterInstanceWorkerService - Critical error forced worker to shutdown|System.Threading.Tasks.TaskCanceledException: A task was canceled.
2024-08-23 11:18:25,195|ERROR|[67]|ASC.Core.Common.Hosting.RegisterInstanceWorkerService - Critical error forced worker to shutdown|System.Threading.Tasks.TaskCanceledException: A task was canceled.
2024-08-23 11:18:25,303|WARN|[67]|ASC.EventBus.RabbitMQ.EventBusRabbitMQ - RabbitMQ: model is shutdown: (null)|System.Exception: AMQP close-reason, initiated by Application, code=200, text='Goodbye', classId=0, methodId=0
Any idea how to fix this issue?
Hello @irdi
Sorry for the late reply.
Please show us your settings on the ‘Automatic backup’ page and provide us with entire DocSpace logs folder: /var/log/onlyoffice/docspace
Additionally, please go to the host and run these commands:
apt list | grep docspace
apt list --installed | grep onlyoffice
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
docspace-api-system/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-api/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-backup-background/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-backup/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-clear-events/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-common/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-doceditor/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-files-services/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-files/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-healthchecks/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-login/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-migration-runner/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-notify/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-people-server/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-proxy/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-radicale/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-socket/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-ssoauth/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-studio-notify/squeeze,now 2.6.0.432 all [installed,automatic]
docspace-studio/squeeze,now 2.6.0.432 all [installed,automatic]
docspace/squeeze,now 2.6.0.432 all [installed]
onlyoffice-documentserver-ee/squeeze,now 8.1.1-26 amd64 [installed]
Screenshot of automatic backup page:
Docspace logs:
https://cloud.redlinedcs.com/s/ZscYR3YaR7JrQ8X
Thanks for the support!
Could you please check out RabbitMQ service status? Please run rabbitmqctl status command and show us the output results.
Additionally, provide us with RabbitMQ logs folder. It should be located here: /var/log/rabbitmq/
Status of node rabbit@denalidocspace ...
Runtime
OS PID: 880
OS: Linux
Uptime (seconds): 961866
Is under maintenance?: false
RabbitMQ version: 3.9.13
Node name: rabbit@denalidocspace
Erlang configuration: Erlang/OTP 24 [erts-12.2.1] [source] [64-bit] [smp:16:16] [ds:16:16:10] [async-threads:1] [jit]
Erlang processes: 862 used, 1048576 limit
Scheduler run queue: 1
Cluster heartbeat timeout (net_ticktime): 60
Plugins
Enabled plugin file: /etc/rabbitmq/enabled_plugins
Enabled plugins:
Data directory
Node data directory: /var/lib/rabbitmq/mnesia/rabbit@denalidocspace
Raft data directory: /var/lib/rabbitmq/mnesia/rabbit@denalidocspace/quorum/rabbit@denalidocspace
Config files
Log file(s)
 * /var/log/rabbitmq/rabbit@denalidocspace.log
 * /var/log/rabbitmq/rabbit@denalidocspace_upgrade.log
 * <stdout>
Alarms
(none)
Memory
Total memory used: 0.1522 gb
Calculation strategy: rss
Memory high watermark setting: 0.4 of available memory, computed to: 13.1426 gb
binary: 0.1037 gb (53.31 %)
code: 0.032 gb (16.44 %)
other_system: 0.0203 gb (10.44 %)
other_proc: 0.0193 gb (9.94 %)
connection_other: 0.0065 gb (3.32 %)
allocated_unused: 0.0044 gb (2.25 %)
other_ets: 0.0031 gb (1.58 %)
connection_readers: 0.0023 gb (1.19 %)
atom: 0.0013 gb (0.69 %)
queue_procs: 5.0e-4 gb (0.25 %)
metrics: 4.0e-4 gb (0.2 %)
connection_channels: 3.0e-4 gb (0.14 %)
mnesia: 2.0e-4 gb (0.1 %)
msg_index: 1.0e-4 gb (0.06 %)
connection_writers: 1.0e-4 gb (0.05 %)
plugins: 0.0 gb (0.02 %)
quorum_ets: 0.0 gb (0.02 %)
stream_queue_procs: 0.0 gb (0.0 %)
stream_queue_replica_reader_procs: 0.0 gb (0.0 %)
mgmt_db: 0.0 gb (0.0 %)
queue_slave_procs: 0.0 gb (0.0 %)
quorum_queue_procs: 0.0 gb (0.0 %)
reserved_unallocated: 0.0 gb (0.0 %)
stream_queue_coordinator_procs: 0.0 gb (0.0 %)
File Descriptors
Total: 50, limit: 65439
Sockets: 39, limit: 58893
Free Disk Space
Low free disk space watermark: 0.05 gb
Free disk space: 193.8006 gb
Totals
Connection count: 39
Queue count: 15
Virtual host count: 1
Listeners
Interface: [::], port: 25672, protocol: clustering, purpose: inter-node and CLI tool communication
Interface: [::], port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
Logs:
Thank you! We’re checking the situation.
Hello @irdi
Please clarify a few things:
  • Does manual backup creation work?
  • Have you tried to resave backup settings?
  • what is the amount of data on the portal?
  • have you changed any config files on the server side? For example, RabbitMQ settings?
This is the second time this happens. The first time it started working without doing anything, and now it stopped without doing anything. It is a serious issue, especially if someone does not check backups regularly, and could cause data loss.
Tests I have done so far include, changing backup time and saving again, putting backup time with 1 hour of difference for each Spaces instance, restarting everything.
This pops up on the logs when triggering manual backup. The backup is succesfull but still it logs this error.
2024-08-27 09:25:43,074|ERROR|[32]|ASC.EventBus.RabbitMQ.EventBusRabbitMQ - ----- ERROR Processing message "BackupRequestIntegrationEvent { Id = b8c16bd6-12c8-4780-b309-c330f780f092, CreateOn = 8/27/2024 9:25:43 AM, CreateBy = 03f56b9a-f807-486f-b479-67373f3bb537, Redelivered = False, TenantId = 15, StorageType = ThirdPartyConsumer, StorageParams = System.Collections.Generic.Dictionary`2[System.String,System.String], IsScheduled = False, BackupsStored = 0, StorageBasePath = , ServerBaseUri = , Dump = False, TaskId = b6a88c94-b093-422a-abec-d9824746a414 }"|ASC.EventBus.Exceptions.IntegrationEventRejectExeption: Exception of type 'ASC.EventBus.Exceptions.IntegrationEventRejectExeption' was thrown.
   at ASC.Data.Backup.IntegrationEvents.EventHandling.BackupRequestedIntegrationEventHandler.Handle(BackupRequestIntegrationEvent event)
   at ASC.EventBus.RabbitMQ.EventBusRabbitMQ.ProcessEvent(String eventName, IntegrationEvent event) in /home/jenkins/workspace/appserver.deb/install/deb/debian/build/server/common/ASC.EventBus.RabbitMQ/EventBusRabbitMQ.cs:line 435
   at ASC.EventBus.RabbitMQ.EventBusRabbitMQ.ProcessEvent(String eventName, IntegrationEvent event) in /home/jenkins/workspace/appserver.deb/install/deb/debian/build/server/common/ASC.EventBus.RabbitMQ/EventBusRabbitMQ.cs:line 410
   at ASC.EventBus.RabbitMQ.EventBusRabbitMQ.Consumer_Received(Object sender, BasicDeliverEventArgs eventArgs) in /home/jenkins/workspace/appserver.deb/install/deb/debian/build/server/common/ASC.EventBus.RabbitMQ/EventBusRabbitMQ.cs:line 279
Thank you, we are looking into it.
Hello @irdi
Could you please double-check that there’s enough free space on the AWS side where you save backups?
Yes, there is enough space.
Please go to the host and restart backup services with these commands:
systemctl restart docspace-backup-background.service
systemctl restart docspace-backup.service
After that please check if the situation is changed.
Thanks for the tip, but I have already tried that and also restarting everything. I think triggering a manual backup will re-activate triggering the automatic backups. Ill report back tomorrow if it worked or not.
I confirm that triggering a manual backup after reconfiguring the automatic backups make it work again.
The issue is why this happens in the first place? This could cause data loss if someone does not notice that the automatic backups are stuck without a reason at all.
Hello @irdi
Thank you for the provided details.
We are still investigating the situation. I will contact you as soon as possible.
Dear @irdi
Please notify us if you face the same issue again.
This is happening again out of the blue. Worked fine till 14 of December.
In rabbitmq logs, i see some bad header errors.
2024-12-16 06:14:19.713867+00:00 [error] <0.2430.18> {bad_header,<<“GET /squ”>>}
2024-12-16 10:02:11.481543+00:00 [error] <0.8350.18> {bad_header,<<“MGLNDD_5”>>}
Manual backup triggering works fine.
It seems there are some other logs:
2024-12-17 13:08:36,238|ERROR|[61]|ASC.EventBus.RabbitMQ.EventBusRabbitMQ - ----- ERROR Processing message "BackupRequestIntegrationEvent { Id = 122314e4-2c9a-4e14-aebe-24ef788817d7, CreateOn = 12/17/2024 1:08:36 PM, CreateBy = a37ee56e-3302-4a7b-b67e-ddbea64cd032, Redelivered = False, TenantId = 8, StorageType = ThirdPartyConsumer, StorageParams = System.Collections.Generic.Dictionary`2[System.String,System.String], IsScheduled = True, BackupsStored = 30, StorageBasePath = , ServerBaseUri = , Dump = False, TaskId =  }"|ASC.EventBus.Exceptions.IntegrationEventRejectExeption: Exception of type 'ASC.EventBus.Exceptions.IntegrationEventRejectExeption' was thrown.
By what i understood it seems it was unable to communicate with the third party storage provider but when trigerring manual backups it does not give any errors.
Hello @irdi
Let’s start from scratch.
What is your current version of the DocSpace and how exactly have you set up autobackup option? Please share a screenshot of your settings.
Additionally, please reproduce the issue and provide us with entire DocSpace logs folder.
It seems that rebooting the system restarts that auto backup process but i would really like to understand why the triggers get blocked and i can not seem to figure it out. I will provide full logs the next time it happens before restarting the system.
Thanks for your support.
