ONLYOFFICE Mobile: Documents
OS version: Android 14
App version: 8.3.2
Mode: On Device
Hi,
Could you please consider adding autodetecting delimiter for CSV files, apps like Google Sheet or Excel Mobile has this feature and in my opinion it’s very useful (manual changing delimiter should be possible as well imo).
The problem I have with current approach is when I open document for first time, I do not necessarily have to know what is the delimiter.
Above is the prompt displayed while opening CSV.
Best Regards,
dedoci
Hey @dedoci
Thank you for the suggestion!
We’ve taken your feedback into account. Autodetecting delimiters for CSV files definitely sounds like a useful improvement.
If there’s any important news or updates on this topic, I’ll make sure to share it here.
Thank You so much for that
, also if possible could You please consider detecting encoding as well? So after opening the CSV file, the first thing we see is the actual content of the file - in my opinion that’s very useful improvement.
Hello @dedoci
Thanks for the suggestion. We will consider it too!
