'Auto-save' and 'Quit'
When a document is closed via ‘x’ or the File dropdown menu, a notification/alert prompts whether to save if there have been changes since the last ‘save’,
Is there also an auto-save feature that is operative in Desktop Editors (“Docs”)?
And if the app is ‘Quit’ are there similar prompts about saving changes made since the last save?
Thanks.
Hello @mk7z,
Yes, there are prompts for the above-mentioned cases. There is no global auto-save available for Desktop Editors (please note, that Docs is a different product which is integrated with Document Management Systems, automatic saving can be enabled there), only Save Auto-Recover information setting in Advanced Settings (which allows to restore a copy of a document in case of unexpected document closure, but it is not the actual document saving)
