Hello!
onlyoffice-desktopeditors 7.5.1-23
Unic function
https://helpcenter.onlyoffice.com/onlyoffice-editors/onlyoffice-spreadsheet-editor/Functions/unique.aspx
- select the MULTI cell where you wish to display the result,
- click the Insert function icon situated at the top toolbar,
or right-click within a selected cell and select the Insert Function option from the menu,
or click the icon situated at the formula bar, - select the Look up and reference function group from the list,
- click the UNIQUE function,
- enter the required argument,
- press the Ctrl+Shift+Enter key combination.
As a result, it does not add {}
Cells take the value of the first sample in the array with a source shift
