Apt-get upgrade onlyoffice-communityserver dependency fail
My community server rev is old.
But when I run apt-get upgrade onlyoffice-communityserver I get a dependency exception.
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 onlyoffice-communityserver : Depends: elasticsearch (= 7.16.3) but 7.17.10 is to be installed
                              Depends: dotnet-sdk-7.0 but it is not going to be installed
My packages look like
ii dotnet-apphost-pack-6.0 6.0.16-1
ii dotnet-host 7.0.5-1
ii dotnet-hostfxr-6.0 6.0.16-1
ii dotnet-runtime-6.0 6.0.16-1
ii dotnet-runtime-deps-6.0 6.0.16-1
ii dotnet-sdk-6.0 6.0.408-1
ii dotnet-targeting-pack-6.0 6.0.16-1
ii elasticsearch 7.10.0
ii onlyoffice-communityserver 12.0.0.1726
ii onlyoffice-controlpanel 3.5.0.516
ii onlyoffice-documentserver 7.3.3-49~stretch
ii onlyoffice-xmppserver 12.0.0.126
Any suggestions on a fix? On Ubuntu 20
Hi @ivan
Please note that we recommend to make backup of the data (or snapshot) before performing any actions on the server.
Take a look at this instruction before performing the update
  1. Download the following script via terminal:
    wget https://download.onlyoffice.com/install/install-Debian.sh
  2. After that please update your components of ONLYOFFICE by execution following command:
    sudo bash install-Debian.sh -u true -it WORKSPACE
Thanks Nikolas
I’ll try this weekend after a backup of the OO VM :wink:
Ivan
Hi Nikolas…
The upgrade process went “OK”, I saw no issues BUT 3.
[1] ALL the ports I use were LOST. I use 6443 for SSL into portal and 5433 into DOC server. These were replaced by 8083 8082 etc. is there a way to preserve the existing ports in use?
(nginx conf ???)
[2] I have a commercial wild card CERT onlyoffice.key and onlyoffice.crt IN THE RIGHT place but the upgrade did not find these or apply them
[3] My configuration for doc server and mail server were all lost
The database seemed OK.
I backed out to a backup.
Any ideas what causes 1,2,3??
Thanks
Ivan
How accurate is this for current release of community server.portal.doc server running in bare metal Configuring OnlyOffice Docs with non-standard port - Aurora Corporate documentation
hello, Ivan
it was necessary to start with this part :slight_smile:
You used a third-party instruction to install ONLYOFFICE (Configuring Only Office Docs with non-standard port)
Usually we recommend to change ports via installation script or docker flags: Installing server version with additional script parameters - ONLYOFFICE
This way you will keep your custom ports during the update steps. As for guide which you followed, we didn’t test it, so we cannot provide any guarantees of stable work.
our installation script
Change the installation script for yourself
or
after updating try to re-set the port values that you changed according to the instructions you provided.
I have resolved this! Thanks.
We are glad that the problem was solved :+1:
