How can I do SUM(E3:E)
, ie. sum all cells below E3?
I can sum the entire column with SUM(E:E)
but is there a way to apply a formula to a semi-infinite range ?
The use case is that I need the formula to be applied to new data as they are added at the end of the range without worrying about a possible limit.
Thanks in advance, I know this is probably a noob question but I couldn’t easily find how to do this (after some googling, searching this forum and asking an LLM).
In case it matters :
I’m using the desktop editor version 8.1.0.169 (x64 exe), downloaded from the website.
