ONLYOFFICE Docs v7.3 released: enhanced forms, SmartArt, new security settings, Watch Window, and more
Api.CreateTextForm is not a function
For feature suggestions, describe the result you would like to achieve in detail:
DocumentBuilder version: 7.2
Installation method: download zip
OS: windows 11
docbuilder.exe ./samples/test.docbuilder
test.docbuilder:
builder.CreateFile("docx");
var oTextForm = Api.CreateTextForm({"key": "Personal information", "tip": "Enter your first name", "required": true, "placeholder": "First name", "comb": true, "cellWidth": 3, "multiLine": false, "autoFit": false});
oParagraph.AddElement(oTextForm);
builder.SaveFile("docxf", "CreateTextForm.docxf");
builder.CloseFile();
is Error
execute_run_code: var oTextForm = Api.CreateTextForm({"key": "Personal information", "tip": "Enter your first name", "required": true, "placeholder": "First name", "comb": true, "cellWidth": 3, "multiLine": false, "autoFit": false});
execute_run: Uncaught TypeError: Api.CreateTextForm is not a function
online is work
Hello @huzedong2022
We are checking the situation. I will update this post when we have something to share.
Use ONLYOFFICE DESKTOP and open the Dbug mode to learn better
Hello @huzedong2022
Sorry for the late reply. It took us some time to figure out the situation.
Thank you for valuable data. We’re going to fix mentioned scenario in DocumentBuilder v.7.3. We’re planning to release v.7.3 as soon as possible.
